![]() | Home > In Car Electronics > Does it help you having a rear camera? |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Well, the OP has a 2009 RRS, do not think there was a factory fitted one on those(even less surround cameras)
Please enlighten me, what is your point?
B.Safe, here one option
Not true...no point me getting annoyed - thanks for your input im off ![]() but ill leave you with the first post: and 3 of the 4 replies that followed were from people with it factory fitted...and surround camera's mentioned only came factory fitted - you cant even retrofit them... no need to get sensitive ![]() ill need to now click that dont watch button Mike 2014 Facelift Discovery |
Good bye, please close the door when leaving |
i almost slammed it - but it had one of those very annoying self close arms that resulted in me just getting annoyed with the door and it still not slamming...ruined my dramatic exit. Mike
Yes I hate when that happens, you are all pep up for a show exit and that damned thing ruins everything.
You two made up |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
You can buy the Gvif interface unit from www.hids4u.co.uk You can buy a camera on Ebay for around £10. If you buy the camera that fits in number plate light , then it will be a problem to hide wires on glass upper tailgate. I fitted a round camera just above towbar cover panel ( easiest place for wire connections. Any ICE Shop should have the no how on fitting as it is plug and play unit itisme |
Never fell out ![]() 2014 Facelift Discovery |
