Home > Maintenance & Modifications > Rearview camera
flydive
Rearview camera
I got the rearview camera from hids4u on the Disco3 forum.
Installation is quite easy, main job is pulling the wires, the power and round wires need to be extende a bit(1.3 m)
Unfortunately my GVIF is an old one, so no guiding lines available.
Here the camera, that replace one of the plates lights, fits snugly and you have to enlarge a bit the bulb holder hole a bit with a file.
Now the wiring, I drilled a small hole in the plastic trim to pull the wiring through the opening glass
Unfortunately there is no easy way to open the glass surround to pull the wires(on the disco you have plastic covers that can be removed) so I had to go the "dirty way, taping the wires around the window, let's see how long it hold, will think of a better solution later
Then pulled the wires through the roof, is easy to pull down the ceiling and route the wires
Then down the inside the side moulding.....
.....to the rear light, connect the wires to the reverse wire and to ground, also, connect a wire to the camera's power wire to go to the GFIF for it to automatically switch when reverse selected
pull the video wire and the power(for the GVIF) inside the boot side panel to the rear seat and under the sills cover to the LH seat were the GVIF is located
this is the final result
Have a lot of plasters available, you are going to need them Wink
. '08 RRS TDV8
Post #283117 Wed Dec 15 2010 6:01pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Excellent. Many thanks....
Alex
Post #283121 Wed Dec 15 2010 6:15pm
buellbeast
How does it wire up into the rear of the screen?
Post #283223 Fri Dec 17 2010 5:29am
flydive
I you mean how it wires up to the camera itself, well it just goes through the plastic cover at the bottom of the screen to the light holder, I will dismantle it and take a picture, but not today, it is snowing here. '08 RRS TDV8
Post #283224 Fri Dec 17 2010 9:19am
I think buellbeast means how does it connect into the back of the GVIF RRS gone
Post #283225 Fri Dec 17 2010 10:39am
Sizzle TDV8
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Isn't there a dedicated RVC input ?? 2007 RRS TDV8 Stornaway Grey with lots of smiles..
2007 Audi A4 2.0T Cabriolet
Missing - 2008 Suzuki GSX-R 750
Post #283349 Sat Dec 18 2010 2:06pm
Rislar
I did mine here:
LINKY
The GVIF connects to the Sat Nav under the seat and the module has a dedicated RCA input for the camera and 3 others for DVD TV etc! If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #283352 Sat Dec 18 2010 2:16pm
christophebcn
Spain
flydive, did you ever get around to find a "cleaner" solution for the wires in the back window?
instead of the "dirty way, taping the wires around the window"?
Thanks
Post #292223 Mon Mar 14 2011 11:23am
flydive
No, I did not, well actually I did not look for one yet, waiting for warmer weather Wink
The problem with the RRS is that the upper tailgate does not have a removable plastic surround like the Discovery.
For the time being the black duct tape is holding up Wink '08 RRS TDV8
Post #292230 Mon Mar 14 2011 1:03pm
christophebcn
Spain
Well, i did mine as well and was hoping i could pass the cables inside the tube (for lack of a better word) where all the existing cables go along the side of the window but it's just not going to happen...
it looks like that 'tube' is filled with something like rubber or silicon once the cables have been passed...
I ended up doing like you except i passed the wires in the rubber tube where the original harness goes.
And no plasters needed Thumbs Up
Post #292362 Tue Mar 15 2011 3:37pm
flydive
Little update, I since added a switch that allows me to switch on the camera at will, the screen will switch automatically '08 RRS TDV8
Post #303296 Sat Jun 18 2011 3:08pm
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
Guess this only works on newer models with the TV???
Post #303341 Sun Jun 19 2011 11:23am
