Home > Technical > Starting problem, battery or alternator
cubbyno9
Hi all,
Over the last few weeks I have been having a problem with starting the car. If I leave the car for a day and come back the battery is flat as a pancake. I have a battery charger, connect this and car starts no problem. Stop and start the car over the day and all is good. However if I leave it for a day, dead !
This happened before about 6 months ago and through AA cover I got a new battery and all was fine. They checked the alternator and it was fine. They can see no discharge draining away on the battery.
Also since this started, when I jump in and put key in and start the car straight away (when it is starting ok) I get HDC warning message. If I turn the ignition on without starting the engine, let it run through prechecks then start car and all is ok. Could this be related to the the battery draining and getting charged several times and the car's computer getting its nickers in a twist.
I would have thought a new battery should last more that 6 months, any ideas what could be going on.
Thanks
Craig 2017 Range Rover Sport HSE
Post #361411 Wed Oct 31 2012 10:22am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Get the output of the Alternator checked asap, they often break down..
Post #361417 Wed Oct 31 2012 10:55am
cubbyno9
yes I plan to get AA to check again when I get back from Belgium today, thanks. 2017 Range Rover Sport HSE
Post #361419 Wed Oct 31 2012 11:03am
drdelrrs
Check your new battery is the exact same spec. as original; the Smart Charge electronics in alternators look for a match (Amp/hr and cranking rate) it can cause unusual glitches if its non-standard.
Post #361423 Wed Oct 31 2012 11:51am
cubbyno9
Will do, Thanks guys 2017 Range Rover Sport HSE
Post #361424 Wed Oct 31 2012 11:58am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Did you get this sorted?
I've read in other posts that the upper tailgate (glass) switch is known to corrode and create a short which flattens the battery. Pull the rubber off and have a look at the switch.
Let us know how it goes. Thumbs Up
Post #363211 Thu Nov 15 2012 9:31am
cubbyno9
Hi Kav,
No it is still the same. My wife has been using the car so all been ok but as a test I left it from Friday when I got back from London to Sunday and it was flat. I will check the rear tailgate when back home at weekend, thanks.
Post #363213 Thu Nov 15 2012 9:35am
kav1187
Ok mate - let us know how it goes. Good luck Thumbs Up
Post #363216 Thu Nov 15 2012 10:09am
cubbyno9
Hi guys, sorry for the delay getting back to you.
Car still doing the same. Had AA out today and checked battery, it's fine. However they have found a drain on the battery when engine switched off. Don't know if it's related but I have had an issue with the Adaptive front lighting system, the warning light has been flashing on the dash but the system was working ok. I was mucking about the fuses today, number 56 and 61 and they looked ok, I took them out and placed back in and the dash light is now out. I will check for a drain on the battery tomorrow in the daylight, very surprised if that's all it was.
I am well pleased the dash light is now, the only the is the drain on the battery, fingers crossed this is all related and the drain has now stopped. 2017 Range Rover Sport HSE
Post #365114 Sat Dec 01 2012 9:25pm
