Home > Technical > Uo416 fault code |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 |
I've had a few problems with the suspension over the last few weeks and reading up on here I thought it could be a compressor, I've had the codes read and it's uo416. They say its a problem with the adjustment switch in the car.
Tue Nov 13 2012 9:25pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
U0416 is a comms failure. You need to check every other ECU on the car for fault codes, as this code is a "cascade" fault. I.E not the true issue
Wed Nov 14 2012 6:37am |
I'm sure Mitch won't mind me posting these up.
Wed Nov 14 2012 11:12am |
P140 is an EGR code IIRC. As yours is an 06my, it can be ignored
Wed Nov 14 2012 12:47pm |
C1A13 - Pressure does not decrease when venting gallery
Wed Nov 14 2012 1:10pm |
Thanks for the replys guys. After Boysey fault coded it I had it done again to see what come up after it had been reset. That was the only code that come up but today I had it done with a auto logic system and it said that the suspension ride height sensors are out of sync.
Wed Nov 14 2012 7:46pm |
Usually on the D3, C1A13 is a broken black/blue wire (or blue/black ) in the wiring loom behind the n/s/f wheel arch. As the car in question is an 06MY, its a good place to start Could potentially be a blocked drier, or a sticky exhaust valve itself |
Thu Nov 15 2012 6:41am |
I use an Autologic system daily, and the only fault I have seen that resembles what you decribe is a "cross articulation fault" Try a calibration first, if that doesnt work, then you need to start replacing height sensors. There is no way to determine which one is causing the issue. Start by removing the arms and see if they move smoothly, and freely. If they are tight, replace them. This could potentially lead onto having to repalce all 4 sensors. If it is loosing pressure from the gallery, there is an air leak someplace. The air tank under the passenger side is becoming more common for leaking. scrape off all the loose rust around the front end of the tank, start the car, put it in off road height so the compressor fills the tank fully, and spray with soapy water. Any leaks should be evident by the bubbles appearing As for EGR's, I know you dont want to, but just blank them. Fit and forget. Causes no issues with the car whatsoever |
Thu Nov 15 2012 6:46am |
I'll replace all 4 height sensors, that was it elimates them then. I think they were only 25 quid each or something like that.
Thu Nov 15 2012 8:32am |
Blanking egrs is fine for yours Mitch.
Thu Nov 15 2012 9:42am |
As Bodsy says, no issues wit hblanking EGR's. Have done hundreds of sets on 05/06MY's and never had an issue. Never noticed an increase in smoke either. It really is a win/win |
Fri Nov 16 2012 6:51am |
Ok I'll give it a go. It's only 20 odd quid for the kit anyway. |
Fri Nov 16 2012 7:59am |
