Home > Technical > cooling system |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Depends how badly they are leaking, but normally with a leaking cooler, you get a coolant loss, with no visible leaks, and sometimes some white smoke out of the rear.
Mon Nov 12 2012 8:04pm |
maddie Member Since: 10 Jan 2011 Location: HERTFORDSHIRE Posts: 6 |
Thanks for your info going to have a snif test done that will at least say either coolers or head gasket have losts
Wed Nov 14 2012 8:23am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Mine is going in next week for another starter motor issue (had a new one fitted earlier this year!) and I've also asked them to look at some coolant loss. Looking at Disco-Mikey's point about loss with no leaks etc, I'm guessing it'll be an EGR cooler issue. 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 14 2012 3:17pm |
Hope it is the coolers a bit less cash to shell out. JEFF GALE |
Wed Nov 14 2012 3:37pm |
I'm hoping it'll be covered by the warranty... 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 14 2012 3:38pm |
