Home > Faults & Fixes > Broken Wheel but brace ?
beastieboy
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
Anyone else had a wheel nut brace supplied on a RRS 2008 or similar ? tried undoing a nut and it split at the top end on one of the joint where the nut end pivots ! nearly broke my arm when it gave way !
seems like a design fault if you ask me !
Post #352955 Mon Aug 06 2012 10:26am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Re: Broken Wheel but brace ?
yep happened to me before, u can nut and bolt it if its the rivet thats broken to get yourself moving if your stuck. They aint cheap to replace either lol
Post #352957 Mon Aug 06 2012 10:36am
beastieboy
just bought the RRS - so hopefully the mainstealer will replace it under the Warranty. Will wait and see what happens then see if I can reenforce it by welding on some extra steel ! It was the rivet that broke which is a joke for "tough" motor and Censored tools !
Post #352958 Mon Aug 06 2012 10:58am
consort
2006 Range Rover Sport Supercharged Java Black
Wheel brace is crap and mine sheared like butter. Also had to remove locking wheel nut that was ruined by tyre shop. Now that is a job!!
Post #362272 Wed Nov 07 2012 5:25pm
