![]() | Home > Tips & Tricks > Low washer fluid warning / leak on the washer tank |
moi7i Member Since: 27 Jul 2011 Location: Nr CHICHESTER Posts: 17 ![]() ![]() ![]() |
I have the same problem but local garage said it would be about Ģ150 for new bottle and labour |
RRSCS Member Since: 07 Mar 2012 Location: Budapest Posts: 19 ![]() ![]() ![]() |
The washer tank can be fixed by a special glue (i.e. the crack can be filled), so you might not need to have the whole washer tank changed. It is not a big work, since only the front bumper must be removed, after that the washer tank is reachable and they can remove it easily by unscrew the screws. Do not let them fool you. |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
Hi Guys.
