Home > Tips & Tricks > Low washer fluid warning / leak on the washer tank
RRSCS
Hungary 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi there,
I just wanted to share with you the following problem I had lately with my RRS. I had the 'low washer fluid' warning on. Even though I filled the tank in the evening and got the signal cleared, the next morning it appeared again. Where I was parking (on grass) I could not realize that the fluid dropped away during the night due to a crack/leak on the washer tank. The guys at the garage (they just repair LRs) told me that it was not the first one they saw with this problem, it seems to be common. So before you think it is a bad sensor, do a check on the washer tank.
Post #346886 Thu Jun 14 2012 12:46pm
moi7i
United Kingdom 2006 Range Rover Sport TDV6 HSE Tonga Green
I have the same problem but local garage said it would be about �150 for new bottle and labour
Post #361651 Fri Nov 02 2012 4:41pm
RRSCS
The washer tank can be fixed by a special glue (i.e. the crack can be filled), so you might not need to have the whole washer tank changed. It is not a big work, since only the front bumper must be removed, after that the washer tank is reachable and they can remove it easily by unscrew the screws. Do not let them fool you. Thumbs Up
Post #361894 Mon Nov 05 2012 9:28am
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hi Guys.
Ia had the same problem with my car, the washing fluid just disappeared,
and I got a puddle on the ground instead
I didn�t had to take the front bumper off, I just loosened the inner wheelarch,
and got access to the tank that way.
In my case it was a o-ring in the connector to the tank that was bad.
I did a "dirty"-repair.. (silicone).
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #361970 Mon Nov 05 2012 5:04pm
