Home > General > TDV8 HSE Spec as standard>
rangersport
Hi all,
What are standard spec on these? As they seem to come very well specced, e.g. 20inch wheels, etc
Is bluetooth standard for example - I have seen one that says phone integration, but not bluetooth, is this the same thing? Also is the fridge in the armrest standard? - all I have seen seem to have it!
Trying to google the added features of the TDV8 but cannot find anything specific (and I think they are all HSE aren't they?)
Post #361351 Tue Oct 30 2012 8:57pm
Tim in Scotland
Pre 2008MY (2008MY cars are cars built after September 2007) had a phone cradle under the centre cubby box lid, it needed an extra adapter for anything other than a Nokia 6330 I think. There was still Bluetooth as well. After 2008MY that was taken out and the car got an electrically adjustable steering column instead. My 2007MY TDv8 was one of the last.
A fridge was standard in the lower section of the cubby box in all pre 2010MY TDv8's which were also all HSE spec or HST spec (ie with a body kit)- check it works 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #361361 Tue Oct 30 2012 10:25pm
rangersport
Thanks. Useful info. Essentially the cradle will be redundant to me. And disadvantage if it being there?
When you say cars built sep07 onwards are my08 - do you mean physically built or registered?
I think the one I am looking at is my07. Would have liked the electric steering column but as long as it is adjustable I can live with that. I assume electric heated seats etc is all still there!
Any other difference between my07 and my08?
Thanks
Post #361363 Tue Oct 30 2012 10:31pm
rangersport
Oh yeah. And is the Nav etc the same or was that updated?
And how those fridges stay so cold? Try are literally like a home fridge!!
Post #361364 Tue Oct 30 2012 10:33pm
Tim in Scotland
MY 2007 would have the phone cradle. LR new model years usually start with cars built from 1st September of the year IIRC
Electric heated seats still there and I think 2008MY went from a DvD based Satnav to a Hard drive but not sure.
The fridge is a "cold plate" system of stored coldness with a fan. They are not running all the time and they are not dependant on the Aircon either. There is a separate on/off switch on the cubby box surround so you don't need to have it as a fridge, CD boxes fit very neatly inside them and there should be a plastic tray lid that will clip on under the cubby box lid.
I have all the sales literature 2005-2010 so need to check the Satnav but it was upgraded before the 2010MY changes came in - the 2005-2008MY cars had a manual column adjust 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #361365 Tue Oct 30 2012 10:42pm
rangersport
Thanks again. Will try to deal a deal in the next day or two and post what I have bought!
The one I am looking at has the lamp guards. Just trying to negotiate with te seller to remove them!
Thanks
Post #361367 Tue Oct 30 2012 10:46pm
simple1
2007/8 HSE should come with 20" wheels, Brembo brakes, satnav and Bluetooth. Dynamic ride and active hesdlights,radar distance control and cruise. Soft leather and fridge. After this some of the original items became pay options 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #361369 Tue Oct 30 2012 10:51pm
Tim in Scotland
IIRC removal of the lamp guards will leave you with some holes in the bodywork...........
Also check the spare wheel - it should be a space saver 19" on a special black alloy unless the owner specced a full size spare - it should not be a small steel wheel. Also check if the car has the tow pack fitted, if it has the detachable tow bar this should be with the car, preferably detached and in it's carrying bag in the boot and NOT left in the receiver where they corrode into place and require a lot of heat and brute force to get out, there shouls also be a removable section of rear bumper to cover the towing gear when not in use 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #361370 Tue Oct 30 2012 10:53pm
Interesting. According to the VIN, my TDV8 is a 2008MY. It has the phone cradle but no electrically adjustable steering column. Bizarre. Mine was first registered early Nov 2007.
I guess the specs were/are variable at MY changeover time... 2012 SDV6 - it's missing a couple of cylinders
Post #361377 Tue Oct 30 2012 11:26pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
my 57 TDV8 HSE had bluetooth, cradle and column adjust!?
beware the sat-nav in all RRS. Biggest let down of the car. Just cannot be relied on at all. Censored ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #361410 Wed Oct 31 2012 10:09am
Yeah, the sat nav is pants and getting updated maps is ridiculously expensive.
I just use a smartphone-based sat nav. Phone bluetooths nicely and the hands free is pretty good. 2012 SDV6 - it's missing a couple of cylinders
Post #361443 Wed Oct 31 2012 3:11pm
Mozilla
Yep, agreed the sat nav isnt the best ! From experience it does have a habit of sending you on a wild goose chase! Banging Head
Post #361448 Wed Oct 31 2012 3:40pm
Not great it may be...but still a trilion times better than Audi's/VW's current effort Thumbs Up
My 57 reg'd car has bluetooth, cradle, fridge but no electronic steering column control (well i don't think so) RRS gone
Post #361449 Wed Oct 31 2012 3:54pm
#76
Dynamic Response
Would a 2007 "07" HSE TDV8 have Dynamic Response fitted as standard?
Also, Adaptive headlights?
Ty.
Smile
Post #361769 Sat Nov 03 2012 10:28pm
It will have the dynamic roll bar yes. Not sure if that denotes "Dynamic Response" though.
It's not the same Dynamic response as the newer cars that's for sure Thumbs Up
Adaptive xenons yes Thumbs Up RRS gone
Post #361884 Mon Nov 05 2012 8:32am
