![]() | Home > Other Site Sponsors > RRS Software Updates for older spec to MY08 spec from Bodsy |
Hi All,
Clock On The Dashboard/Lights On indicator After Clock On The Dash is ENABLED - LOOK a Clock you can see! (Why LR didnt do this in the first place I have no idea.....) This is shown with the Lights switched OFF
This is shown with the lights switched ON so you can now tell if your lights are on or off. This update is now available with the option to have the Lights on Indicator enabled or not enabled. ![]()
And a close up. As you can see, the "Lights On" indicator is in fact the old (No longer used) Fuel Burning Heater indicator and is pale Red. I can also do this with ONLY the clock on the dash, so without the lights on indicator. ![]()
Three Flash Indicators Three Flash Indicators can't really be shown (other than in a vid perhaps) but it is when you tap the indicator and the indicators then flash three times and self cancel. Makes it easy work on motorways etc for changing lanes without you having to remember to switch it off Gearbox Reset/Recalibration This resets your adaptive gearbox back to factory values (it remembers how you drive) it will also recalibrate the Transfer box, combined together, it often results in a smoother drive and has been known to help resolve symptoms of some gearbox juddering. This is not always guaranteed as there can be many causes of this symptom, but this is certainly one of the cheaper options to try first. Sat Nav On The Move This is a long update (90 minutes) but is very very popular as it is incredibly frustrating to have to keep stopping to change your destination. This update allows you or your passenger ![]()
To prove it works when driving...
Thanks to Chris for letting me take the Pictures of his updates ![]() PhoneBook over Blutooth Update This updates your standard factory Fit RRS Blutooth module to enable you to select your phonebook contacts from the screen of your radio display. It also fixes issues with iphone etc where you have to enter the 2121 code in each time you want to connect. I can do this one by post also and its very easy to change on a RRS. service reminder reset This resets your service message. some independants are not able to reset your servcie indicator after they have changed oil etc. this can be reset for another year. Read/Reset Fault Codes Can also Read and reset All fault Codes and provide you with an e-mailed list of any that come up if needed. This could save you a more expensive trip to a dealers. Another popular one is to purge and test the Fuel Burning Heater so that it makes sure it works ready for the winter and update other modules as needed. If you would like any of these updates, then please feel free to PM or e-mail me. It helps if you include your postcode and model year and what updates you would like to have done. ![]() Cheers Ian Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE Last edited by Bodsy on Mon Feb 09 2015 1:39pm. Edited 3 times in total |
Yes, absolutely compatible |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
could do with the bluetooth update as i am sick off putting in 2121 every time i get in the car |
Yes I can sort that, drop me a pm with your details. |
AJS7 Member Since: 23 Oct 2012 Location: London Posts: 8 ![]() ![]() |
Hi Ian,
Sent you an email with more detail |
PHUN in NZ Member Since: 02 Oct 2012 Location: Rotorua Posts: 8 ![]() ![]() ![]() |
Hi Ian,
Will cost you at least an air fare I guess for Bodsy |
Airfare would be good |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
and to norway:) RRS 2006 2.7 HSE |
Hi Ian
Paul, you can email me d3bodsy @ yahoo . co . uk
This Wednesday I will be going down to Gloucester, Bristol, South Wales, then across to dartford, then around dartford Thursday am and then back via Aylesbury and up the m40.
lsnicolo Member Since: 12 Mar 2012 Location: catania Posts: 2 ![]() ![]() ![]() |
I read your post, i would like to know if in Italy is possible to have an adjustment software? Thank you in advance
