Home > Technical > Airbag light on off on off
Nice But Dim
Hi
Airbag light illuminated a few weeks back, it was on off on off so i dropped it and dealers and they diagnosed a loose connection and no charge. fixed.
Airbag now coming back on, only every now and then. Called dealers and they cannot tell me which nut/connector they tightened.
So my question is can anyone tell me where i can start looking for a possible loose connector for this problem, i mean is there a known weak spot or somewhere i should try first.
Any suggestions welcomed.
Thanks --------------------------
RRS S/C, Java Black
X-Type Jag sport
LR D2 GONE
BMW 540 GONE
Post #360955 Fri Oct 26 2012 9:20am
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
i was told of a connection on the steering colum.not excatly sure where but always be carefull when dealing with the airbag.
Post #360959 Fri Oct 26 2012 9:52am
mse
There is a ring behind the steering wheel - it has a name i can never remember - if you arent careful you can damage it and/or it can fail - if it does you get a similar problem Mike
2014 Facelift Discovery
Post #360972 Fri Oct 26 2012 11:43am
Martin
Site Administrator & Owner
Clock spring is the name Smile Like this site? Buy some RRSPORT goodies to show your support!
Post #360977 Fri Oct 26 2012 12:24pm
Nice But Dim
Cheers guys.
Clock spring is possible as when i have the car stationary i can normally get the airbag light to illuminate by turning the steering wheel from side to side.
I do have a airbag removal tool, just a question of wether i am brave enough, i suspect if i disconnect the battery i won't have a airbag exploding in my face when i remove it.
Thumbs Up --------------------------
RRS S/C, Java Black
X-Type Jag sport
LR D2 GONE
BMW 540 GONE
Post #361038 Sat Oct 27 2012 11:32am
