![]() | Home > Technical > Airbag light on off on off |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
i was told of a connection on the steering colum.not excatly sure where but always be carefull when dealing with the airbag. |
There is a ring behind the steering wheel - it has a name i can never remember - if you arent careful you can damage it and/or it can fail - if it does you get a similar problem Mike
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Clock spring is the name |
Nice But Dim Member Since: 15 Oct 2010 Location: Kent Posts: 61 ![]() ![]() ![]() |
Cheers guys.
