![]() | Home > General > Advice please |
Its true that changing rear anti-roll bars (lift body; not remove), turbo-chargers and/or exhaust manifold gaskets require body off (3/4hrs) but its quite rare.
Triple7 Member Since: 27 Oct 2011 Location: Wiltshire Posts: 154 ![]() ![]() |
As above, buy one from a LR Dealer with a full warranty and don't worry...... Gone:
Jonseyi Member Since: 19 Oct 2012 Location: Liverpool Posts: 15 ![]() ![]() ![]() |
Thanks for the info, will start looking , |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
get one preferably still with manufacturers warranty (3 years in UK) and if not add on another year (about £800)
FF1078 Member Since: 25 May 2011 Location: East Yorkshire Posts: 69 ![]() ![]() ![]() |
Go for a 59/10 plate as the dash is sooo much better with better build quality |
Thanks for the advice,
You can get an extended L/R warranty no problem if you motor still has the manufacturers warranty, and is due to run out, however, if your manufacturers warranty has expired, then you can still get a L/R warranty providing that your motor has a full service history and you will have to pay for your vehicle to be inspected by your local dealer to check that there isn't any nasty surprises for them before they sell you a warranty. |
Thanks for the info Ady, at least now I'm not limited to where I get one from. |
Mozilla Member Since: 27 May 2012 Location: London Posts: 30 ![]() ![]() |
Checkout one of my previous posts on general buying advice, hope it helps.
