Home > Technical > MY13 Front End 'Clunk/thud' Noise on Driving Off.... |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
I'd say the best bet Cheney would be to get it back to the dealer sharpish and let them resolve all your issues in one hit. Shouldn't be of any inconvenience to you as they should give you a like for like (or better) RRS/FFRR.
Mon Oct 15 2012 7:53am |
The last time i had a problem like that was when the battery was loose, but that was when going round corners, it would slide side to side, thud thud, good old ford escorts hey Hope you get it sorted, keep us posted. |
Mon Oct 15 2012 8:04am |
Cheney Jawa Member Since: 25 May 2012 Location: Birmingham Posts: 89 |
Thanks Chaps
Mon Oct 15 2012 9:39am |
Ah, I see, seems you're taking it in good spirits.
Mon Oct 15 2012 9:45am |
Is it still pulling to the left? |
Mon Oct 15 2012 9:48am |
Yes To be fair to the dealer they did say if there was no improvement they'd do a complete 4 wheel alignment Beancounter - I think if you didn't take it in good spirits RRS Ownership may very well tip you over the edge!! Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack |
Mon Oct 15 2012 9:53am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
I was talking to my tyre guy recently. He reckons they've seen quite a few new RRS with poor wheel alignment straight out of the factory. He doesn't do alignments himself but sees the results in poor tyre wear. He sends people to get the alignment checked elsewhere and the usual result is that the geometry was just wrong. Having it setup properly results in correct tyre wear and, crucially for him, people who come back when they want new rubber later on.
Mon Oct 15 2012 11:10am |
^^^ Very similar discussion with the alignment place where I got mine done. A whole bunch of RRS's in the in the prior month to mine, all with less than 2,000 miles on the clock, all with varying degrees of alignment trouble.
Mon Oct 15 2012 11:15am |
I'm also told that the dealers won't do the alignment check and setup under warranty because they just claim "you must have hit a pothole". LR dealers aren't exactly cheap when it comes to alignment checks either... 2012 SDV6 - it's missing a couple of cylinders
Mon Oct 15 2012 12:18pm |
Yes, I inquired with a local LR dealer, was told 'about 3 hours work and will be circa £300'
Mon Oct 15 2012 12:30pm |
I got mine done by my dealer, they didn't quibble either, but that was when they were trying to straighten my steering wheel to put it inline with my wheels |
Mon Oct 15 2012 12:39pm |
A somewhat bigger issue ON THE WAY: BMW F21 M140i
Mon Oct 15 2012 12:42pm |
Tyre guy told me that a customer eventually got ProAlign (who make the 4-wheel alignment kit) to look at his Sport at their training facility. His local LR guys had checked it and said it was spot on. ProAlign looked at it and it was quite a bit out. They adjusted the suspension and the owner has been happy ever since. Makes you wonder why dealers bother really 2012 SDV6 - it's missing a couple of cylinders
Mon Oct 15 2012 12:59pm |
I was told that mine definitely left the factory with the symptoms as the adjustment needed could not have been caused by potholes/kerbs etc.
Mon Oct 15 2012 1:01pm |
