Home > Maintenance & Modifications > upper glovebox annoying rattle |
eskimorob Member Since: 05 Aug 2010 Location: Gravesend Posts: 7 |
Yes mine does that, I find if I leave it open it doesn't do it.
Fri Sep 21 2012 6:43pm |
My glovebox was making an annoying buzz. Looked as if it was caused simply by the lid not closing tightly enough so there was a tiny bit of movement. Didn't seem to be any adjustment on the latch and dismantling it to put in a packing piece looked too difficult. In the end I just stuck two 1cm long pieces of sticky backed rubber draught proofing strip http://www.diy.com/nav/build/insulation/dr...908050(one either side of the latch).
Sat Sep 22 2012 1:48pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
I have this problem too. It seems that the latch mechanism itself is what is causing the rattle. I was considerig doing the same as what Paddi has done but there must be a slightly longer rubber bung out there somewhere that will fit?? |
Fri Oct 05 2012 9:00am |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 697 |
Mine too! Java black 2006 |
Sat Oct 06 2012 7:25am |
vic_ster51 Member Since: 21 Sep 2012 Location: east anglia Posts: 28 |
Yeah its seems that it dont fit tight tight as such c ebb |
Mon Oct 15 2012 7:54am |
Has anyone got a BMW? If so can you please check your glovebox and see if the rubber plug is slightly bigger than the RR one?
Mon Oct 15 2012 12:18pm |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 |
I had this driving me mad for 6 months before I figured out how to fix it.
Mon Oct 15 2012 5:38pm |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
No problem with mine, not even on the last one. Then again it is so full usually it can’t move. So thanks to my partner for storing gloves, 3 pairs various colours; scarves, 4 varying styles; and various other garments to cover every eventuality. But certainly never rattles. |
Mon Oct 15 2012 7:46pm |
