Home > Maintenance & Modifications > upper glovebox annoying rattle
vic_ster51
United Kingdom 2005 Range Rover Sport TDV6 HSE Luxury Java Black
Anyone else have this it annoys me sometimes like a little clunky rattle coming from the upper glovebox when on A or B roads sometimes
Just wondered if common and anyone had a little fix
its ok when i have radio blasting out which is most of the time but still c ebb
Post #357457 Fri Sep 21 2012 5:22pm
eskimorob
Yes mine does that, I find if I leave it open it doesn't do it.
Haven't worked out why or what is causing it yet!!!
Post #357465 Fri Sep 21 2012 6:43pm
Paddi
My glovebox was making an annoying buzz. Looked as if it was caused simply by the lid not closing tightly enough so there was a tiny bit of movement. Didn't seem to be any adjustment on the latch and dismantling it to put in a packing piece looked too difficult. In the end I just stuck two 1cm long pieces of sticky backed rubber draught proofing strip http://www.diy.com/nav/build/insulation/dr...908050(one either side of the latch).
The lid now closes tightly - no more buzzing. Bit of a low tech fix Embarassed . One day I'll dismantle the thing and do it properly. One day. Neutral 2008 MY Java Black TDV8 HSE
Post #357522 Sat Sep 22 2012 1:48pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I have this problem too. It seems that the latch mechanism itself is what is causing the rattle. I was considerig doing the same as what Paddi has done but there must be a slightly longer rubber bung out there somewhere that will fit??
Post #358814 Fri Oct 05 2012 9:00am
Kensta
Mine too! Java black 2006
Post #358880 Sat Oct 06 2012 7:25am
vic_ster51
Yeah its seems that it dont fit tight tight as such c ebb
Post #359659 Mon Oct 15 2012 7:54am
kav1187
Has anyone got a BMW? If so can you please check your glovebox and see if the rubber plug is slightly bigger than the RR one?
http://www.ebay.co.uk/itm/BMW-Glove-Box-Co...43b46fe33f
Post #359728 Mon Oct 15 2012 12:18pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I had this driving me mad for 6 months before I figured out how to fix it.
Can't remember how I figured it out but this is how I fixed it
Get yourself some GT85 spray dry lube from Halfords ... Spray the hinges and all metal bits...
Let it dry for 30 mins
You should now be sqeeeek and creeak free.
hope this help
UK Guy RRS HSE with a few extras & a
2013 RRS Autobiography
Post #359791 Mon Oct 15 2012 5:38pm
Hugh Haddow
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
No problem with mine, not even on the last one. Then again it is so full usually it can’t move. So thanks to my partner for storing gloves, 3 pairs various colours; scarves, 4 varying styles; and various other garments to cover every eventuality. But certainly never rattles.
Post #359809 Mon Oct 15 2012 7:46pm
