Home > Technical > Relay click under drivers seat
Perce
There is a clicking noise (every 2 seconds roughly) coming from under my drivers seat. It continues even once the ignition key is removed. I had a quick look and it seems to be coming from the small black box on the left (the one with a chrome bolt showing in the middle of it). I know I will need to probably take it in to the local dealer for repair, but wondered if it was a common fault, and if anyone new of a simple fix.
Post #344291 Sun May 20 2012 4:52pm
abdechich01
Did you find out what the issue was?? I have the same with driver seat and mirror not working. Passenger seat works.
Post #359196 Wed Oct 10 2012 9:07am
Pufftmw
Re: Relay click under drivers seat
Are you sure its not the SatNav reading the DVD? Mine does that all the time & at first I was disconcerted until I worked it out.
Post #359228 Wed Oct 10 2012 11:51am
abdechich01
No it's not because it's a random click (not every 2 seconds) Sad
It's definitely coming from below the seat and the fact that my seats and mirrors don't work I guess it's linked to the ECU Sad
Post #359233 Wed Oct 10 2012 12:14pm
skilachi
Hi, Did you manage to find out what the issue was in the end? Took my car for MOT and as unlock/open the door I could hear the noise.....its like a ticking noisy/timebomb
The driver/memory seat is not working but the mirros are working. Also the passenger seat is work so thinking it could be a fuse.
Saw this in another post
Re: Driver seat and Car side mirror not working
I'd check 33 (5 amp), 54 (5 amp) and 46 (30 amp), in order of "suspicion", all located in the passenger compartment fusebox.
Post #486307 Mon Feb 01 2016 6:32pm
