Home > General > Transmission fault |
Hi and welcome to the site, sorry your first post is not a good one, First off i'd check your battery terminals are good and tight, if all is good have your battery and alternater checked, if all is still good, it may be as simple as a foot brake pedal switch. hope you get it sorted without too much cost, if its none of the above then it will need plugging into a computer to find the fault codes that will be logged. |
Fri Sep 28 2012 8:21am |
1st point of call would be to check your tail light bulbs
Fri Sep 28 2012 9:28am |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Battery. Hopefully. |
Fri Sep 28 2012 9:46am |
