![]() | Home > Faults & Fixes > Adaptive Cruise Control issue - Help needed |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
What do you know indeed.... ![]() ![]() ![]() |
Thank you. You're most kind.
Mr Rox Member Since: 16 Sep 2012 Location: London Posts: 10 ![]() ![]() |
Arrrrrrgghhh.
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
"It does not sound right if you say you need CC for ACC to work."
Seen as uve been on the forum for a relatively short period of time u might not realise but Bobby is a RR Sport guru. Literally a fountain of knowledge. I'm certain that he knows the difference and more than likely down to the component part numbers. |
X5pea thanks for editing your post, the bit at the end condescending to both parties... I really couldn't give a hoot if he designed it from the ground up (no offence Bobby, hopefully you can see were i am coming from ![]() I also didn't realise that the length of time on the forum had any relevance to anything, my bad I have given my self 100 lines and detention..... ![]() Last edited by firstinretail on Wed Sep 26 2012 12:35pm. Edited 1 time in total |
Your welcome old boy. I saw your thread regarding a service and thought that it would be much more fitting in there ![]() ![]() |
Gentlemen, sorry for causing all this! |
As with most forums a gentle bit of banter is to be had. I had no intention of upsetting you, making you feel bad or other nasties |
Ok, so the car has been in with an authorised service centre. They discovered that there was a lose connection behind the steering wheel. Now they're having trouble re-calibrating the unit. The next step they're going to take is removing the front bumper to see if the unit is has somehow been knocked out of place. At the moment I have a yellow warning light symbolising a road with a car flashing on the dashboard...
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
ACC does not work near airports. CC does work near airports.
Rats, another double post. |
iainp100 Member Since: 05 May 2011 Location: saddleworth Posts: 59 ![]() ![]() |
I have ACC and had the same error when i purchased mine it was a wire that had sanpped going throught to bumper A1 landrover diagnosed and sorted it for me for 90 all in Range rover Sport tdv8 with bas touch
