Home > General > Which remap for 2.7d |
When i had my 2.7 remapped i had the same problem, too much smoke on kick down or hard acceleration, so i had my map tweeked to try and reduce it, but it also reduced the power very slightly, mine wasn't set up on a rolling road though, it was an interface that plugs into the cars ecu and is all done via email, so i ended up with 3 maps, one smokey, one a little less smokey, and the original map, which isn't ideal if you tow a trailer or caravan on a regular basis or Pc plod is behind you going up hill. |
Sun Sep 16 2012 7:33pm |
Mavster Member Since: 15 Sep 2012 Location: London Posts: 10 |
OMG Ady,
Sun Sep 16 2012 7:53pm |
To be honest, that was what spoilt the pleasure in driving it with the remap on, the power delivery was great though, it had so much more grunt it was a totally different car but to see the plums of black smoke trails behind was not good, also shortly after the remap i had an egr valve fail i asked myself, was this helped by the remapp, i don't know but it was covered by warranty so i wasn't too bothered. |
Sun Sep 16 2012 8:35pm |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 |
Strange! Have talk to so many others with no prob at all. RRS 2006 2.7 HSE |
Sun Sep 16 2012 10:00pm |
Skipper Member Since: 13 Jan 2011 Location: Essex Posts: 25 |
Most generic maps dump fuel in to compensate the extra boost etc. Hence the smoke. Ideally you need to find someone who can live map your Range. |
Sun Sep 16 2012 11:24pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
Not a good remap indeed, ideally the car should be checked over, remapped, tested and checked by the supplier before parting with any cash. "Roads ? Where we're going there are no roads." Back to the future. |
Mon Sep 17 2012 7:52am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Was it AMD you had an issue with , as the guys there are superb and of course you'd be getting a bespoke remap thats tested on a RR and dyno'd etc.
Mon Sep 17 2012 9:07am |
AmD are great. I am a technical sponsor of the AmD tuning BTCC race car Shaun & the lads look after all my cars.
Mon Sep 17 2012 8:35pm |
Live mapping is the best indeed, but costs a little more than a mere remap. As you say though, it takes serious knowledge of an engine's operation to do it properly and this is beyond mere chip resellers. "Roads ? Where we're going there are no roads." Back to the future. |
Mon Sep 17 2012 9:09pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
I have a BAS Map on my car - improved my 0-100kph time by over 2 secs and I do not have any more smoke than before ie none that is noticeable from the drivers seat.
Tue Sep 18 2012 12:23am |
Yes afraid so, but it was around/ before the time that the Essex branch was set up,.. I was told by them over the phone that is was probably a MAF? problem that was already there before the remap.. |
Tue Sep 18 2012 8:03am |
Thanks Skipper , I didn't realise that the AmD map was a generic map. I assumed as it was done at their premises on a RR and Dyno tested that they did it 'live' and bespoke for each car........you live and learn
Tue Sep 18 2012 8:06am |
The right thing to have done would be making sure the car was running properly, replacing the MAF if necessary before putting a new map on it, imo the suppliers of the remap should have fixed or insisted you fix the car before doing any work on it "Roads ? Where we're going there are no roads." Back to the future. |
Tue Sep 18 2012 8:13am |
^^^ Agree with Froggy ON THE WAY: BMW F21 M140i
Tue Sep 18 2012 8:31am |
