Home > In Car Electronics > Iphone touch connection |
andrewm123 Member Since: 22 Jul 2012 Location: Bromley Kent Posts: 13 |
what is the best way of integrating my iphone4 in a RRS MY06? |
Sun Jul 22 2012 7:46pm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Sounds like you need a cable to fit the iphone and ipod wired into the rear aux socket. This will then give you music through the speakers, charging facility and volume control via the steering wheel but no other functions.
Sun Jul 22 2012 8:27pm |
joeand Member Since: 22 Aug 2012 Location: manchester Posts: 104 |
did you get it sorted as i want the same cheers |
Thu Aug 30 2012 2:33pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
The very best way as far as I know is the official LR kit for doing this, it's a lead that plugs into the back of your radio and runs to the upper glovebox and provides some level of control over the iPod via steering wheel as far as I know. It's called the Audio Connectivity Module (ACM), part number VPLFE0002, approx £300. Seems this is a freelander part, but from what I've seen here, it works with the RRS too. On the cheaper end of the scale, one of these will give you "proper" line level output (rather than headphone) and also has a USB plug so you can charge the iPod from a 12V cig lighter socket: http://compare.ebay.co.uk/like/15086584766...adtype=pla Check it's compatible with the touch, I know it works with an iPhone but not sure about touch. If you have the phono sockets behind the front armrest it will be simple plug and play, if like me you only have a jack for aux input rather than phono, you'll need one of these too: http://www.play.com/Electronics/Electronic...tsid:11518|cat:3515965|prd:3515965 or this which I would prefer http://www.amazon.co.uk/3-5mm-stereo-Phono...y_ce_img_c Now, you won't get any remote control for the iPod from these, only reasonable quality sound, better than you get from the headphone socket which something like this would provide with a little remote http://www.buyijet.com/ (note: I've never tried this, so can't guarantee it's any good, just one I found by googling ipod remotes) "Roads ? Where we're going there are no roads." Back to the future. Last edited by mrfrog on Thu Aug 30 2012 3:20pm. Edited 1 time in total |
Thu Aug 30 2012 3:07pm |
Duplicate post
Thu Aug 30 2012 3:09pm |
is this just plug and play ranege rover say they need to install to activate it ?? |
Thu Aug 30 2012 3:23pm |
Just plug & play. Bought the attached (see link) and works a treat.
Fri Aug 31 2012 11:17am |
andrew that just puts you on there site dosnt show what you brought mate |
Sun Sep 16 2012 3:06pm |
here you go
Mon Sep 17 2012 8:00pm |
It just put you on there site ? |
Mon Sep 17 2012 8:03pm |
link doesn't appear to work. go to Kensington home page via link below, select 'Smartphone', then 'iphone&ipod' then 'cables & accessories. you want 2 in 1 car charger and AUX audio cable |
Mon Sep 17 2012 8:04pm |
Mon Sep 17 2012 8:06pm |
