Home > In Car Electronics > Iphone touch connection
andrewm123
what is the best way of integrating my iphone4 in a RRS MY06?
Post #351488 Sun Jul 22 2012 7:46pm
rigsby
Sounds like you need a cable to fit the iphone and ipod wired into the rear aux socket. This will then give you music through the speakers, charging facility and volume control via the steering wheel but no other functions.
I have used a bluetooth receiver in the rear aux which works perfectly with the phone music but no good for the ipod if it doesn't have bluetooth Big Cry MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #351497 Sun Jul 22 2012 8:27pm
joeand
England 2006 Range Rover Sport Supercharged Zambezi Silver
did you get it sorted as i want the same cheers
Post #355122 Thu Aug 30 2012 2:33pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
The very best way as far as I know is the official LR kit for doing this, it's a lead that plugs into the back of your radio and runs to the upper glovebox and provides some level of control over the iPod via steering wheel as far as I know.
It's called the Audio Connectivity Module (ACM), part number VPLFE0002, approx £300. Seems this is a freelander part, but from what I've seen here, it works with the RRS too.
On the cheaper end of the scale, one of these will give you "proper" line level output (rather than headphone) and also has a USB plug so you can charge the iPod from a 12V cig lighter socket:
http://compare.ebay.co.uk/like/15086584766...adtype=pla
Check it's compatible with the touch, I know it works with an iPhone but not sure about touch.
If you have the phono sockets behind the front armrest it will be simple plug and play, if like me you only have a jack for aux input rather than phono, you'll need one of these too:
http://www.play.com/Electronics/Electronic...tsid:11518|cat:3515965|prd:3515965
or this which I would prefer
http://www.amazon.co.uk/3-5mm-stereo-Phono...y_ce_img_c
Now, you won't get any remote control for the iPod from these, only reasonable quality sound, better than you get from the headphone socket which something like this would provide with a little remote
http://www.buyijet.com/ (note: I've never tried this, so can't guarantee it's any good, just one I found by googling ipod remotes)
"Roads ? Where we're going there are no roads." Back to the future.
Post #355124 Thu Aug 30 2012 3:07pm
mrfrog
Re: Iphone touch connection
Duplicate post Embarassed
Post #355125 Thu Aug 30 2012 3:09pm
joeand
is this just plug and play ranege rover say they need to install to activate it ??
Post #355126 Thu Aug 30 2012 3:23pm
mrfrog
Don't know, but when I asked my local dealer about iPod connectivity for my MY2005 RRS, they drew a blank, nothing in microcat, nobody knew how this could be done !
Post #355129 Thu Aug 30 2012 3:34pm
andrewm123
Just plug & play. Bought the attached (see link) and works a treat.
http://www.kensington.com/kensington/en/gb...cable.aspx
Post #355191 Fri Aug 31 2012 11:17am
joeand
andrew that just puts you on there site dosnt show what you brought mate
Post #356725 Sun Sep 16 2012 3:06pm
andrewm123
here you go
Post #356848 Mon Sep 17 2012 8:00pm
joeand
It just put you on there site ?
Post #356849 Mon Sep 17 2012 8:03pm
andrewm123
link doesn't appear to work. go to Kensington home page via link below, select 'Smartphone', then 'iphone&ipod' then 'cables & accessories. you want 2 in 1 car charger and AUX audio cable
Post #356850 Mon Sep 17 2012 8:04pm
andrewm123
Post #356852 Mon Sep 17 2012 8:06pm
