![]() | Home > General > Random transmission symptom |
Sorry to hear about your gearbox woes, hope it's easily sorted |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
something very similar happened to me in a BMW M6, especially the 'sounds like a bolt' part - a few miles later the transmission blewup.. hello £9k BMW warranty job
could be a worn locator pin? RRS gone
Thanks for the suggestions although rrsboy's story is not very encouraging I have to say |
A quick update on the transmission symptom: had a long-established auto transmission specialist drive the RRS and check for fault codes about a month ago but the symptom wouldn't manifest itself on the test drive and there were no fault codes found. The guy said the shifting (ironically) was the smoothest he could remember. We agreed that I probably had nothing to lose by changing the gearbox oil and filter and am planning to have this done shortly using the kit that can be widely found at parts specialists which includes an LR pan and filter and correct ZF Lifeguard oil. HOWEVER and this is the weird part - the rough shift which happens about once per longish trip seems to be diminishing in severity each time it occurs. Happened once yesterday on the M25 at about 55 mph crossing those numerous lanes to get off at J14 and it was really nowhere near as harsh as previous occassions . Is it possible that previous owner did all short trips and the box is gradually feeing up after rarely getting into top gear? Or is that just wishful thinking?
Might be worth having the gearbox reset and transfer box recalibrated. |
Bodsy,
