Home > General > Random transmission symptom |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Sorry to hear about your gearbox woes, hope it's easily sorted
Wed Sep 12 2012 1:10pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
something very similar happened to me in a BMW M6, especially the 'sounds like a bolt' part - a few miles later the transmission blewup.. hello £9k BMW warranty job
Wed Sep 12 2012 2:28pm |
could be a worn locator pin? RRS gone
Wed Sep 12 2012 2:43pm |
Thanks for the suggestions although rrsboy's story is not very encouraging I have to say . What does the locator pin locate? It seems there are an awful lot of systems that can input information to the transmission and at the moment I'm hoping it is one of these that is not working properly. One of the systems is steering input and can it be coincidence that on both occasions the rough shift occurred shortly after a bit of steering input? I've read that the first thing to do when investigating engine management problems is to check and clean all the connector plugs and wonder if the same applies to transmission management systems? 2008 MY Java Black TDV8 HSE
Thu Sep 13 2012 11:59am |
A quick update on the transmission symptom: had a long-established auto transmission specialist drive the RRS and check for fault codes about a month ago but the symptom wouldn't manifest itself on the test drive and there were no fault codes found. The guy said the shifting (ironically) was the smoothest he could remember. We agreed that I probably had nothing to lose by changing the gearbox oil and filter and am planning to have this done shortly using the kit that can be widely found at parts specialists which includes an LR pan and filter and correct ZF Lifeguard oil. HOWEVER and this is the weird part - the rough shift which happens about once per longish trip seems to be diminishing in severity each time it occurs. Happened once yesterday on the M25 at about 55 mph crossing those numerous lanes to get off at J14 and it was really nowhere near as harsh as previous occassions . Is it possible that previous owner did all short trips and the box is gradually feeing up after rarely getting into top gear? Or is that just wishful thinking?
Thu Nov 08 2012 4:25pm |
Might be worth having the gearbox reset and transfer box recalibrated. Bodsys Brake Bible
Fri Nov 09 2012 12:52am |
Bodsy,
Fri Nov 09 2012 3:08pm |
