Home > In Car Electronics > Aux not working |
You might have tried this but...
Tue Sep 04 2012 1:30am |
belink Member Since: 03 Sep 2012 Location: Brazil Posts: 4 |
of course and nothing... |
Tue Sep 04 2012 1:32am |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Hai, have you checked to make sure the multi plug that feeds the aux socket is connected ?
Tue Sep 04 2012 6:16am |
hi, no i don't checked this... how can i do it?
Tue Sep 04 2012 9:15pm |
Hi Belink, if you lift the flap up that covers the aux socket and lighter socket the whole thing will pull towards you, it will be stubborn but put your thumb in the lighter socket to give a decent grip and with the other hand prise off one of the bottom corners and it will release. You will find two connectors, 1 for the cigarette lighter that just pulls off and a green connector with 3 wires that pulls out sideways once you press the tab. To refit, make sure the wires are tucked out of the way and push the unit firmly back in and it will lock into place. If the wires are fitted ok it may be worth trying another unit if you know someone local to you.
Tue Sep 04 2012 10:05pm |
thanks for the answer i'll try this and later i will post here the results. thanks |
Tue Sep 04 2012 10:12pm |
