Home > Wheels & Tyres > What is the procedure for taking wheels off an RRS?
Page 1 of 4 1234>
RRS09
United Kingdom 2009 Range Rover Sport TDV6 HST Santorini Black
Hi, I want to take the wheels off my Range Rover Sport in order to have them refurbished. It's the first Range Rover I've owned, I have a quick lift jack and axle stands but just want to confirm that they're suitable to leave under the car as I'm told it can affect the air suspension. Is it the type of job you have to do on a 4 poster ramp or is it okay to take the wheels off one at a time with the stand in place? Also I've been told that you have to leave the tailgate open to save the suspension moving once the car is in the air? Thanks.
Post #355361 Sun Sep 02 2012 1:48pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Can't see why you couldn't use axle stands provided you're putting them under something solid. They'll need to be pretty tall or you'll some packing under them to raise them.
As for the suspension, yes, the car may try and level itself while being lifted, so a door/tailgate open stops this happening. If you're doing all four at once, I'd disconnect the battery before starting anything.
Maybe (not sure), locking the suspension in access height will stop it playing about when raised.
"Roads ? Where we're going there are no roads." Back to the future.
Post #355364 Sun Sep 02 2012 2:55pm
RRS09
Thanks for your reply, as for disconnecting the battery, will that result in me losing a radio code? Thanks again.
Post #355365 Sun Sep 02 2012 2:59pm
defender_uk
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
yes you will....
Post #355366 Sun Sep 02 2012 3:01pm
SRE
Spain
WHAT radio code ? Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #355368 Sun Sep 02 2012 3:09pm
RRS09
Well, seeing as I've been advised to disconnect the battery, I need to know if I will lose the code or not? Or do Land Rovers/Range Rovers not have one?
Post #355369 Sun Sep 02 2012 3:15pm
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
There is no radio code Thumbs Up
Post #355371 Sun Sep 02 2012 4:17pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
keep the tailgate open and the hazard lights on = air suspension doesn't re-adjust itself
Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #355374 Sun Sep 02 2012 5:17pm
mrfrog
Ditto, no radio code on mine either, you might loose radio presents and the clock will need resetting on the radio if this is where yours is.
Post #355377 Sun Sep 02 2012 5:25pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Hanging the wheels has to be done in extended hight, did this before the summer to rotate the tyres, once up in the air with your hi lift jack stick axle stands under chassis rails and you will be fine
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #355389 Sun Sep 02 2012 7:46pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
Spot on.
Be very carefully lifting all the wheels of the ground at the same time(as some ramps do) it can blow the Censored out of the compressor. If you took some fog and put it in a jar, would it be missed.
Post #355391 Sun Sep 02 2012 8:08pm
mse
Sorry, procedure for jacking the car is really important
Its air suspension to MAX height, hazards on. I always was shown to open the windows, but not sure why or if you need to.
Tailgate does not need to be open.
Jack away (avoiding the compressor on the chassis rail) Mike
2014 Facelift Discovery
Post #355432 Mon Sep 03 2012 4:55pm
A simple safety measure I always did was but the wheel under the chassis in case the RRS slipped off the jack. I used to have an air jack which was fab lifting the car. 2005 Zambezi TDV6 - Gone but not forgotten
Post #355438 Mon Sep 03 2012 5:52pm
mse
There are a few jack safety tips...the wheel one can be useful - but not always the thing to do.
I have 2 3t pro jacks 4 3t individual axle stands and 2 2ton jacks and im never 100% confident under them...but the professional jacks make the home jacks look scary Mike
Post #355444 Mon Sep 03 2012 6:40pm
firstinretail
That's Censored sorry, a door has to be open this disables the suspension, but a door can blow shut so the tailgate is used. Try adjusting the suspension with a door or tailgate open, nothing to do with the windows. Forums are dangerous when wrong info is given out ! If you took some fog and put it in a jar, would it be missed.
Post #355445 Mon Sep 03 2012 6:45pm
Page 1 of 4 1234>
