![]() | Home > Wheels & Tyres > What is the procedure for taking wheels off an RRS? |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
Can't see why you couldn't use axle stands provided you're putting them under something solid. They'll need to be pretty tall or you'll some packing under them to raise them.
RRS09 Member Since: 02 Sep 2012 Location: Wales Posts: 10 ![]() ![]() ![]() |
Thanks for your reply, as for disconnecting the battery, will that result in me losing a radio code? Thanks again. |
defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169 ![]() ![]() ![]() |
yes you will.... |
WHAT radio code ? ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Well, seeing as I've been advised to disconnect the battery, I need to know if I will lose the code or not? Or do Land Rovers/Range Rovers not have one? |
DMike Member Since: 09 Nov 2007 Location: Perthshire Posts: 79 ![]() ![]() ![]() |
There is no radio code |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
keep the tailgate open and the hazard lights on = air suspension doesn't re-adjust itself
Ditto, no radio code on mine either, you might loose radio presents and the clock will need resetting on the radio if this is where yours is. ![]() "Roads ? Where we're going there are no roads." Back to the future. |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Hanging the wheels has to be done in extended hight, did this before the summer to rotate the tyres, once up in the air with your hi lift jack stick axle stands under chassis rails and you will be fine
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
Spot on. Be very carefully lifting all the wheels of the ground at the same time(as some ramps do) it can blow the ![]() |
Sorry, procedure for jacking the car is really important
A simple safety measure I always did was but the wheel under the chassis in case the RRS slipped off the jack. I used to have an air jack which was fab lifting the car. 2005 Zambezi TDV6 - Gone but not forgotten
There are a few jack safety tips...the wheel one can be useful - but not always the thing to do.
That's ![]() |
