Home > General > Fuel Burning Heater
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Fuel Burning Heater
Is there any way to check the FBH is working correctly before the winter comes ? 2009 3.6 TDV8 HSE Santorini Black
Post #354804 Tue Aug 28 2012 10:52am
mark hamster
do you no anybody with a BIG fridge Whistle Whistle
Post #354812 Tue Aug 28 2012 11:39am
shakeapaw
take it to iceland Mr. Green 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #354813 Tue Aug 28 2012 11:44am
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Still too warm there..you'll need to find somewhere below 4 deg C!
Post #354815 Tue Aug 28 2012 12:00pm
shakeapaw
give over, our local iceland sells frozen ice cubes, so it must be cold Mr. Green 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #354823 Tue Aug 28 2012 12:23pm
mjbrr
Useful !!!!
Censored 2009 3.6 TDV8 HSE Santorini Black
Post #354879 Tue Aug 28 2012 7:29pm
Martin
Site Administrator & Owner
Yes, it can be run using a LR-specific diagnostic tool, or if you're a bit more hands on then the Webasto diagnostic software (free) and an adapter can connect to it and run it. Like this site? Buy some RRSPORT goodies to show your support!
Post #354891 Tue Aug 28 2012 9:30pm
toeuk1
Hello all. My FBH is locked out (was informed of this when the car got remapped last year). I've read about a fuse removal - ignition off/on sequence that can sometimes enable the heater to reset.
Am I right in thinking that the said sequence is as follows?
Open bonnet,
Ignition off with key out,
let the car go to "sleep" (park brake lamp off),
remove fuse 28 from the engine bay fuse box,
put fuse back in after a couple of minutes and that's it?
This is what I found on the Disco site, but I'm sure I've read somewhere else the ignition should be on when fuse is removed.
Any pointers or links to the correct way of doing this would be much appreciated.
Cheers.
Post #360980 Fri Oct 26 2012 2:34pm
Martin
Do this (I wrote it up): http://www.disco3.co.uk/wiki/index.php/Fue...#Resetting
Ignition must be OFF. Like this site? Buy some RRSPORT goodies to show your support!
Post #360981 Fri Oct 26 2012 2:46pm
Mitchmx
How do I know if I got one on my rrs. Is it a standard hse thing?
If its standard. How do you use it? Embarassed
Post #361010 Fri Oct 26 2012 10:45pm
fkarim
Open the bonnet and if you have one fitted you will see this:
http://www.rrsport.co.uk/forum/post251393.html#251393
It's function can't be controlled (unless you have an aftermarket device) and will only come on automatically if the temperature is 4 deg C or lower, the engine is running and I think climate control needs to be on too.
I always knew I had it but reading some threads on this forum convinced me it was broken/locked out as I didn't see any smoke even today. Decided to check it out and three burnt fingers with the impression of the wrinkly pipe suggested otherwise Laughing
If you can't see any smoke, can't smell or hear anything unusual, one (relatively safer than mine) way to check it's working is to locate its exhaust pipe. It can be easily seen through the front offside wheel arch on a RHD car. Hold a piece of paper against that outlet and you will know if there is gas coming out of it.
Post #361014 Fri Oct 26 2012 11:55pm
Martin
Read up the whole page at that link I posted to DISCO3 Smile Like this site? Buy some RRSPORT goodies to show your support!
Post #361015 Sat Oct 27 2012 12:07am
toeuk1
Thanks for that confirmation Martin - much appreciated.
Post #361019 Sat Oct 27 2012 7:24am
Mitchmx
Ahh I'll check the disco3 link.
Seams like most topics are linked to disco3 forum Laughing
Post #361023 Sat Oct 27 2012 8:59am
Mitchmx
That post is the Censored Very Happy looks like it know what I'm doing today! Thumbs Up
Post #361024 Sat Oct 27 2012 9:11am
