![]() | Home > Maintenance & Modifications > RRS engine issue |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
If you're lucky, it'll just be a split in the intercooler hose - new OEM one is about £50 or an upgraded silicone one that'll last longer from Bell Automotive (site sponsor) for around £100. |
Coxlong Member Since: 01 Aug 2012 Location: UK Posts: 21 ![]() |
Thanks for the reply.
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Possibly a blocked fuel filter?
REVs fine when stationary, no issues.
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
Revving fine when stationary is no indication that all is well, when the car is running at speed, the ECU takes all sorts of input such as load on engine, intake air temps, fuel temperature, and plenty more to make a decision on how much fuel to inject and maybe how much boost to allow into the engine. So the parameters for fuelling will be wildly different on the run and a split hose would not manifest itself much when stationary but would show up on a run. ![]() "Roads ? Where we're going there are no roads." Back to the future. |
Very little fuel draw when reved stationary so not a test for restricted fuel supply. |
