Home > General > Suspension failure ?!
bulletooth
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Was wondering if someone on here could shed some light on a recent problem
I've had with the range rover ! .. The car drives and handles fine in every way but after a few minutes of driving a message will appear on the dash saying ' suspension system error , and it will then come
Up with a warning light which is of a car with an arrow either side pointing to the floor ? . If you turn the ignition off and back on this all goes and is fine again but re-appears after another few minutes of driving .. Any help would be great ! ..bulletooth.
Post #354653 Sat Aug 25 2012 5:39pm
kroutvar
Czech Republic
I am afraid there will be not much help here.The only thing which will help will be to take the car to a dealer or an independent shop to read the faults from EAS ECM...could be anything from faulty brake light switch,height sensor,wiring etc,etc... Neutral
Post #354654 Sat Aug 25 2012 5:57pm
bulletooth
Well I was just wondering if someone on here had a similar problem in the past and how they had gone about fixing it
Post #354655 Sat Aug 25 2012 6:01pm
drdelrrs
When I had "suspension fault" message. Here's what I did without diagnostic equipment... not foolproof.
If you lower car to access level and then select max. height and message "suspension raising slowly" appears its a good indication of a lazy compressor and/or relay.
If it takes a while to reach max height and/or the "raising slowly" message does not go off its probably sensors.
If it rises smoothly your probably looking at a duff height sensor - you'll need some one with diagnostic kit to isolate which one.
If the rise occurs at rear first and then jerkily at front it could be relay can also be compressor leaking off or a front sensor.
Hope that helps.
Post #354660 Sat Aug 25 2012 6:56pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
check your power steering fluid mate, the ARB is hydraulic and if its running dry will bring on the light.
Had this issue myself in the past showing the same symptoms as yourself.
Post #354661 Sat Aug 25 2012 6:59pm
bulletooth
Thats a great help actually because what I forgot to add was that when raising the suspension up , the rear rises first then the front rises jerkily ..
Post #354662 Sat Aug 25 2012 7:01pm
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Doesn't the rear raise first, I had this and a new compressor sorted it Thumbs Up 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
L.E.D. lights throughout.
Post #354670 Sat Aug 25 2012 8:02pm
bulletooth
The rear raises first then then the front , isn't it supposed to raise level? How much am I looking at for a new compressor ? Sad
Post #354672 Sat Aug 25 2012 8:06pm
Big ken
I paid £502 for compressor fittedn Thumbs Up 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
Post #354673 Sat Aug 25 2012 8:07pm
simple1
Picture of a car with side arrows is dynamic ride as far as I know. Mine comes on if I travel at 90 plus for long periods. Abroad obviously. Turning ignition off on restarting puts light out. Am told that at @ 90, suspension lowers to help high speed stability. I guess mine gets confused and gives up. Does come on odd time when towing caravan too. Mine goes up at rear first, then front but no jerking. The suspension works on air not hydraulic so ignore steering fluid as cause. More likely to be air leak or pump fault, both are not unusual. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #354679 Sat Aug 25 2012 9:41pm
Tim in Scotland
You can check if the height sensors are faulty by switching to the offroad screen - the page that shows the wheel articulation/ diff locks on/off etc - there is a small bar shown above each wheel on the screen, if any are red then that one has a fault.
Checking the power steering oil is important if your car has the Dynamic Response / ACE fitted as this electro-hydraulically adjusts the antiroll bars on cars with with DR/ACE/ auto dislocating ARB's (generally all TDv8's and all S/C's have that, some 2.7HSE's might have had it as an optional extra as some where specced with 20" wheels and DR from the factory - these cars will also have the uprated steering rack required to fit bigger than 19" wheels on pre-2007MY cars) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #354683 Sun Aug 26 2012 9:06am
