Home > General > Suspension failure ?! |
kroutvar Member Since: 29 Dec 2011 Location: Semily Posts: 4 |
I am afraid there will be not much help here.The only thing which will help will be to take the car to a dealer or an independent shop to read the faults from EAS ECM...could be anything from faulty brake light switch,height sensor,wiring etc,etc... |
Sat Aug 25 2012 5:57pm |
bulletooth Member Since: 13 Aug 2012 Location: Berkshire Posts: 22 |
Well I was just wondering if someone on here had a similar problem in the past and how they had gone about fixing it |
Sat Aug 25 2012 6:01pm |
When I had "suspension fault" message. Here's what I did without diagnostic equipment... not foolproof.
Sat Aug 25 2012 6:56pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
check your power steering fluid mate, the ARB is hydraulic and if its running dry will bring on the light.
Sat Aug 25 2012 6:59pm |
Thats a great help actually because what I forgot to add was that when raising the suspension up , the rear rises first then the front rises jerkily .. |
Sat Aug 25 2012 7:01pm |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 |
Doesn't the rear raise first, I had this and a new compressor sorted it 2.7 TDV6
Sat Aug 25 2012 8:02pm |
The rear raises first then then the front , isn't it supposed to raise level? How much am I looking at for a new compressor ? |
Sat Aug 25 2012 8:06pm |
I paid £502 for compressor fittedn 2.7 TDV6
Sat Aug 25 2012 8:07pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Picture of a car with side arrows is dynamic ride as far as I know. Mine comes on if I travel at 90 plus for long periods. Abroad obviously. Turning ignition off on restarting puts light out. Am told that at @ 90, suspension lowers to help high speed stability. I guess mine gets confused and gives up. Does come on odd time when towing caravan too. Mine goes up at rear first, then front but no jerking. The suspension works on air not hydraulic so ignore steering fluid as cause. More likely to be air leak or pump fault, both are not unusual. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Aug 25 2012 9:41pm |
You can check if the height sensors are faulty by switching to the offroad screen - the page that shows the wheel articulation/ diff locks on/off etc - there is a small bar shown above each wheel on the screen, if any are red then that one has a fault.
Sun Aug 26 2012 9:06am |
