Home > Maintenance & Modifications > Lowering question |
V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338 |
You can manually change it mm by mm. Maximum drop is 28mm I think. Maximum if you want to keep the option of access mode is about 18 |
Fri Aug 24 2012 4:47pm |
Every mm you lower will effect the ride quality.
Fri Aug 24 2012 9:17pm |
