Home > Maintenance & Modifications > Lowering question
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
Lowering question
I see where you can install "lowering modules". Does that make the car ride the same as when I have used the lowering button
on the console? Thx! mike murphy
Post #354605 Fri Aug 24 2012 4:18pm
V88ABA
2007 Range Rover Sport Supercharged Java Black
You can manually change it mm by mm. Maximum drop is 28mm I think. Maximum if you want to keep the option of access mode is about 18
Post #354609 Fri Aug 24 2012 5:47pm
Every mm you lower will effect the ride quality.
Mines -25mm and is slightly firmer without being "bouncy" RRS gone
Post #354620 Fri Aug 24 2012 10:17pm
