Home > General > After MOT one xeon brighter than other
ajp166
Guys I was driving this eve after the MOT this morning and cars are flashing their lights at me as one main xeon is brighter than other! This has heppened before and revere corrected it as I have the Revere sidelights fitted.
Is this a common issue? Can I just adjust myself?
Post #354484 Wed Aug 22 2012 10:31pm
Not heard of that before Confused
Sounds like a trip back again to the chaps at Revere Neutral ON THE WAY: BMW F21 M140i
Post #354485 Wed Aug 22 2012 10:42pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
@ajp166
Hello,
Probably itīs Your shutter in the main light that is stuck in the "hi-beam"position.
It is not an uncommon fault.
The light has a shutter like an eyelid inside to, when You select "hi-beam", open up and
let all light out, and when You select "lo-beam", close again.
Easy check: Give the offending headlight a tap, see if it dims.
There is a fix, Iīve read about it on the D3-forum.
If You are a bit technically inclined, You can do it Youself.
You have to take out the headlight, turn it upside down, remove the motor for the adaptive
lights, under there is the solenoid that close/opens the shutter.
Its the rod that is connected to the shutter that has to be gently cleaned with a very fine
sandingpaper.
Hope that this helps you..
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #354523 Thu Aug 23 2012 1:36pm
