Maxarn58
@ajp166
Hello,
Probably itīs Your shutter in the main light that is stuck in the "hi-beam"position.
It is not an uncommon fault.
The light has a shutter like an eyelid inside to, when You select "hi-beam", open up and
let all light out, and when You select "lo-beam", close again.
Easy check: Give the offending headlight a tap, see if it dims.
There is a fix, Iīve read about it on the D3-forum.
If You are a bit technically inclined, You can do it Youself.
You have to take out the headlight, turn it upside down, remove the motor for the adaptive
lights, under there is the solenoid that close/opens the shutter.
Its the rod that is connected to the shutter that has to be gently cleaned with a very fine
sandingpaper.
Hope that this helps you..
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Thu Aug 23 2012 1:36pm |
