Home > Technical > Average speed and mpg on information centre
ducati_andy
Hi everyone
May be a silly question but I have done around a 100 miles on my 56 plate tdv6 since I picked it up Monday, and noticed the mpg seems to be stuck at 25.9 and the average speed at 31.0, I see in the book it is per 100 miles, but surely it should have updated the averages? The miles left on the tank and trip etc seem to be updating ok,
Any ideas.
Thanks Andy
Post #354448 Wed Aug 22 2012 6:12pm
Bulkoboy
I had this issue .you need to reset every so often all you need to do is turn on ignition and then press the I button on the left hand stalk for about 5 seconds till it goes to four dashed lines .. It's as simple as that hope this helps
Post #354458 Wed Aug 22 2012 7:22pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
thats because its doing 25.6 mpg, if you start thraSHING IT round town it will start dropping and if you re set it as said above it will re adjust its self over a PEriod off time
Post #354462 Wed Aug 22 2012 7:51pm
ducati_andy
Thanks will try the reset, just expected it to update a bit more dynamically like other cars I've had.
It should hopefully do a few more miles to the tank than my last car, 190 Smile
Post #354478 Wed Aug 22 2012 10:38pm
