![]() | Home > Technical > Average speed and mpg on information centre |
Bulkoboy Member Since: 05 Feb 2012 Location: Warwickshire Posts: 6 ![]() ![]() |
I had this issue .you need to reset every so often all you need to do is turn on ignition and then press the I button on the left hand stalk for about 5 seconds till it goes to four dashed lines .. It's as simple as that hope this helps |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
thats because its doing 25.6 mpg, if you start thraSHING IT round town it will start dropping and if you re set it as said above it will re adjust its self over a PEriod off time |
ducati_andy Member Since: 10 Aug 2012 Location: leics Posts: 12 ![]() ![]() ![]() |
Thanks will try the reset, just expected it to update a bit more dynamically like other cars I've had.
