Home > General > Cost of side steps fitted
The only worry I would have about having 3rd party steps (or other items) fitted to a new vehicle is the possible impact on the car's warranty. One of the stipulations for the warranty is that the car is unmodified - getting LR to fit items in the first month gets around this of course.
Now, this might not be an issue with something like side steps (although I wonder if it might be used as a get out if there are any early corrosion issues) but other items might be a problem.
Just mentioning it to cover both sides of the "argument" Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #353260 Thu Aug 09 2012 9:08am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
56k id be canceling and buy from another dealer, decen discounts to be had on new RRS at the moment.
Post #353264 Thu Aug 09 2012 10:14am
mse
I dont think there are decent retail discounts especially at the minute - certainly no more than usual. Charging for mats is common - especially as there is demand for the car, certainly in some places there is less demand, but thats then different...in the midlands certainly there is a good demand
This is not strictly true
First of all you make a common mistake between an accessory and a modification (a modification is something say to the engine (eg remap), suspension (eg raise or lower) or body (eg gulwing doors) etc - all examples there are more)
Side steps are an accessory - now there is still a rule that the vehicle needs to be fit for purpose and meets needs you could reasonably expect of it - also there is another rule about servicing/warranty that gets you into the world of a patterned part being to the same spec as an OEM - they cant make you only buy their.
Equally you can fit anything (if you were worried say only genuine parts/accessory to avoid arguments) at any point in or out of warranty - all that will happen is that part will only carry a 12 month warranty not 3 yrs
Dont start me on explaining your corrosion warranty - but i wouldnt worry about that Thumbs Up Mike
2014 Facelift Discovery
Post #353299 Thu Aug 09 2012 4:06pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
I would walk away from the entire deal and have a chat with James over at LPR.
Jim
Post #353310 Thu Aug 09 2012 5:32pm
Good point re: modification vs. accessory. 2012 SDV6 - it's missing a couple of cylinders
Post #353311 Thu Aug 09 2012 5:34pm
x5pea
au contraire , mate of mine just took delivery of a red edition 2 weeks ago and got a crazy discount on it.
Demand always slows down when the cars go into in run out stages, Like every other manufacturer LR are starting to PIMP up the std models to muster up some interest before the new model is release.
Prices are already starting to fall
Post #353325 Thu Aug 09 2012 8:17pm
mse
Im not sure that is true - demand is still up and there is still a long time before the replacement sport is due - its true its not exceeding demand like the evoke, but its not anywhere near the point of needing to shift cars
What sort of percentage did he get? 10%? Mike
Post #353334 Thu Aug 09 2012 9:06pm
