Home > Faults & Fixes > Sounds like tin can dragged under + feels like gritty wheels |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Sounds like stones trapped in the brakes, Quite a common problem. The best thing is to try and throw them out by hard braking - obviously don't do this on a street with people behind you Find a safe place and accelerate then brake hard. It usually gets rid of any stones or grit. This has happened to me a few times. Sometimes they will be thrown out after just a few attemps, other times it takes ages or you may end up with a visit to a garage to get them removed. Good luck 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Wed Aug 01 2012 7:12pm |
sunseeker Member Since: 10 Sep 2011 Location: England Posts: 43 |
Endjin
Wed Aug 01 2012 7:18pm |
Trust me mate it CAN sound horrendous. The last time I had it I was in the middle of nowhere on a single track road in the highlands and it sounded like I had a mixture of tin cans on string(as you described) and really loud Squeeling when I turned the steering. From what you've described I am pretty certain this is your problem, but, hey, if you are worried then of course, take it to a garage to be checked out. Better safe than sorry. Oh, and yes the brakes felt terrible as well! 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Wed Aug 01 2012 7:24pm |
Thanks again...
Wed Aug 01 2012 7:42pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Mine made this sound and it was the electronic park brake... |
Wed Aug 01 2012 10:34pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
HDC switch on ??? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Aug 27 2012 1:14pm |
Does the sound change if you apply the brakes (stuff between pads and disc)?
Mon Aug 27 2012 4:55pm |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
Also - does the sound vary when turning? Between left & right turns? |
Mon Aug 27 2012 7:17pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
Could be wheel bearings, the wheel wobbles/grinds until you hit the brakes which temporarily straighten everything.
Mon Aug 27 2012 7:47pm |
