![]() | Home > For Sale & Wanted > Wanted: Headlamps converted to DRL / Black internals..? |
moparmuff Member Since: 25 May 2012 Location: S. Bucks Posts: 96 ![]() ![]() ![]() |
AWD man can I just confirm the ring sizes I note you mention if you did it again you would
Wow £20 is there a link to the bay What sort of glue did you use to stick them on ? |
Baben Member Since: 14 Feb 2008 Location: Kyalami Posts: 29 ![]() ![]() ![]() |
the angel eyes are
OMG they make the CA lights look rather expensive |
The only concern I'd say is if you're taking the time to split your headlights, make sure you get some quality LEDs in there, otherwise you'll only be re-splitting them in 3 months because the "cheap" ones have stopped working |
I know |
^^^ He'd definitely recommend getting a set that are the same size for each side |
