Home > Faults & Fixes > Alternator burnt out, how long did yours last.
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Sadly my TDV6 alternator started to burn last night when I parked the car in the drive at home, spotted the smoke and horrible acrid plastic smell and quickly removed the positive from the battery, which stopped a fire. Took the AA 2.5 hours to come out to look at it only to tell me what I already knew, that it had a major short circuit. Car has now been recovered to my local garage for a new Alternator to be fitted today. The car has only done 40,000 miles so should the alternator go wrong at such a low mileage? PS The AA man said is this a 2006 -2007 model year (which it is) so there is a known problem!
Post #352015 Fri Jul 27 2012 11:58am
Timo in Leicester
Mine gave up at 60,000 miles. 2007 v6. A slow death, the non charging light came on when on the motorway, but got home and local independent swapped it.
Post #352020 Fri Jul 27 2012 1:36pm
1JBS
Car came back yesterday, all running smoothly. Question do the alternators fail more often on Range Rovers than any other car on the road?
Post #352400 Tue Jul 31 2012 8:25am
Mike767
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
My 2006 Disco 3 went at 90K. Electrical burning smell and battery light came on. I believe the issue is the diode pack which is part of the alternator. Easy enough to replace but you need the viscous fan spanners to get the fan off.
Post #358064 Thu Sep 27 2012 10:30am
drdelrrs
23,000 miles on TDV8 - my dealer reckoned a non-standard battery (100 a/hr) presumably fitted by the previous owner's dealership, was not compatible with the charge controller and led to the alternator's early demise.
Alternator and battery changed by my dealer under warranty with no hassle.
Interestingly the new battery, although rated lower at 90 a/hr, actually spins the motor faster at start-up!
Post #358112 Thu Sep 27 2012 6:42pm
Rover T
Ireland 2008 Range Rover Sport TDV6 HSE Stornoway Grey
My altenator packed up on Monday at 54K miles. Battery light came on and stayed on in the dash. New one fitted along with a belt and when they were at it ,the belt tensioner bearing was bad ,it replaced also.....
Should it not have lasted longer???got no abuse.
Post #364840 Thu Nov 29 2012 4:42am
MEV6
Whats the standard rough cost of an alternator replacement on the RRS? My last car an Audi RS6 went pop at 60k which you could almost bet your wife on that. £900 to fix Shocked 2007 Black on Black colour coded TDV8
Post #365793 Fri Dec 07 2012 7:46pm
Bandit8
England 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I had to get mine changed at 39000 miles and the cost form a none LR dealer was £365.00 all in. This was a replacement LR part and not a new one. I was told that a new LR one would cost around the £600 mark. Shocked Shocked
Worked well for the 3 days I had it before I sold the car.... Rolling Eyes It is what it is and I am what I am....
Post #365803 Fri Dec 07 2012 9:01pm
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
has any of these problems acured a wineing sound from engine when revveing u ?? 2007 COOLRRS
Post #387543 Mon Jul 01 2013 11:27pm
Bodsy
Site Sponsor
Whiny sound with revving is usually the air con clutch. Or could be one if the bearings for the aux belt usually the tensioner.
As for the alternator, mine went at 116k so it does seem quite random when they will fail. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #387555 Tue Jul 02 2013 7:53am
Advanced Factors
Site Sponsor
Bit late for you chaps, but for the next to pick up on this thread.....
http://www.advancedfactors.co.uk/dan-987-a...e-74-p.asp
£211.42 for new Denso unit
And we keep a decent quantity in stock! Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #387597 Tue Jul 02 2013 3:18pm
Bodsy
Site Sponsor
I can fit these as well if needed. Thumbs Up Bodsys Brake Bible
See it HERE
Post #387598 Tue Jul 02 2013 3:41pm
simonsti
England 2013 Range Rover Sport SDV6 HSE Nara Bronze
Just had mine replaced, it was overcharging the battery. £250 plus fitting. 2014 Nara Bronze SDV6
GONE TDV6 HSE RRS in Giverny green,Ebony interior, Side steps,Tints, PTI, Tow pack, mud flaps, Side strips and Dynamics pack.
Post #401287 Wed Nov 06 2013 3:43pm
jochem00
86.000 KMS or some 50.000 Miles.
believe the battery was naggered which meaning the alternator had to charge permanently.
had Airbab light coming on every once and a while.
changed battery and alternator and all faults are gone too
Post #402640 Mon Nov 18 2013 7:38am
embar76
Poland 2007 Range Rover Sport TDV8 HSE Java Black
My alternator burned at 118 000km. TDV8/2007
Post #408869 Thu Jan 09 2014 7:21pm
