![]() | Home > General > 2012 RRS 3.0 HSE SDV6 |
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 ![]() |
mw I have read your many posts with interest but I think sadly you are expecting too much of LR or the dealer - lowering head below the parapet
I know how mw feels have had a similar problem with a Jeep Grand Cherokee in the past I just do not want him to lose a load more money like I did.
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Thanks Paul |
rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216 ![]() ![]() |
The only reason I can see for buying a D4 is the load space - you get loads more in than the RRS
Disco cheaper, all weather tyres and as you say bigger inside |
^^^^ But it ain't no sport |
Or ditch the caravan |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
You are aware, I assume, that the RRS is just a Disco with a different frock on. They might have firmed up the suspension but it's still a Disco underneath. Having said that, the first Disco was a Range Rover with a different frock on too but that's a different story... One might, if being silly, make the comparison between the RRS and the Disco as being between two sisters. One is gorgeous and everyone wants her; the other is somewhat plainer but is actually the one you should marry because she does everything ![]() Hmmm, I think I need to get out in the sunshine - been staring at a screen too long today and it's addled my brain ![]() 2008 TDV8 - it was a labour of love and is much missed |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
I can confirm that the RRS is just as good off-road as the D4, yes. ![]() ![]() ![]() 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
The RRS will always lose out on ground clearance to the D3/4 though and, ultimately, this would be a limiting factor. You would need to be trying to get it stuck though... 2012 SDV6 - it's missing a couple of cylinders
Oh yes im aware the running gear is the same...very good access to that stuff.
According to LR's figures, with the SDV6 engine, the RRS and the D4 have the same mpg figures and basically the same 0-60 times too (0.3s in it). The D4 has slightly larger external dimensions but that does then give it greater interior space too. Top speed is a bit less but who does more than 100mph in either vehicle anyway? Weights are pretty close to each other too.
Me too |
