Home > Technical > HELP - Stuck Key in Tow Bar |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 |
Ive had the same issue previously. I removed the Tow ball and laid it on its side to allow WD40 to soak through the lock overnight. Then i exercised the lock & the key came out easily and never had a problem since. The sprig loaded cam should exercise when it is in out of the vehicle aslo. hope this helps |
Thu Jul 19 2012 9:17am |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
I had a similar problem recently on my new RRS.
Thu Jul 19 2012 9:43am |
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 |
Thanks. I can see the bolt (is it the big piece of silver square metal?) but it doesn't appear to be protruding outside the hole - should it be completely hidden/recessed way down in the housing ? See photo below... When I turn the green knob, it moves slightly and I can see the bolt moving slightly but that is about it.
Thu Jul 19 2012 11:52am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
On the other side you should see a small silver pin - it is when this is depressed it releases the pin in your pic locking it to the socket... |
Thu Jul 19 2012 1:01pm |
Perfect Fixed it. There was nothing wrong with it. It appears that the key only comes out when it is locked in place (or thinks it is locked in place) Did what you said and the key came out. I had to put it back in though and reset in order to get the big bolt to retract in order to get it attached to the car, at which point the green knob popped and secured in place. Thanks for your help Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone) |
Thu Jul 19 2012 2:36pm |
Thu Jul 19 2012 3:27pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Was guilty of this too the first time I messed around with my tow bar when I got the car ON THE WAY: BMW F21 M140i
Fri Jul 20 2012 4:39am |
