Home > General > Please Help!!!! Just lost power on motorway!!!! Cruise Prob? |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
range rovers are like microsoft computers, u just switch em off and on again and carry on regardless.
Fri Jul 13 2012 3:37pm |
mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111 |
Hi X5
Fri Jul 13 2012 4:28pm |
V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338 |
This happened to me the other day too various times, no lights or codes Mines going into lr as soon as I'm back home! LR assist however won't pick it up as they say car is drive able so unfortunately has to go to local stealer as opposed to LPR! |
Fri Jul 13 2012 4:49pm |
V88ABA - Were you using cruise control too? Any idea what you pressed? Did you get a message come up?
Fri Jul 13 2012 5:24pm |
Ok here is what has just developed..........................Doing 60MPH in cruise control so I started to accelerate to get the cruise to drop out (After 60 seconds I think??) after about 40 seconds a message came on saying "Engine System Fault" but no loss of power this time.
Fri Jul 13 2012 6:41pm |
EGR valves ???? Oh and change your sig to.... When its broke, get it fixed |
Sat Jul 14 2012 7:38pm |
Lol Thanks Ady!!!!! It had the EGR replaced 2/3 weeks ago apparently.
Sat Jul 14 2012 8:21pm |
JT888 Member Since: 20 Apr 2009 Location: Surrey Posts: 54 |
Mike, I had a not disimilar problem a couple of years back in 2.7 TDV6 RRS.....I was driving along at around 80Mph on a motorway and all of a sudden lost all engine power....had to force my way across 3 lanes of traffic onto the hard shoulder, somewhat shaken. Turned the car off then on again and all appeared to be ok, but it then did the same thing 3 miles further down the road. Needless to say I would have been all the more furious had this happened to my wife whilst she was driving alone as she would probably have panicked and ended up stopped in lane 3 on the M4.....not good. When LRAssist/AA turned up, the bloke couldn't even drive the car up onto the low loader as there was virtually no drive/power whatsoever. I confess that this was the final straw and why I got rid of the RRS, although i'm keen to get into another one (albeit hopefully more reliable!). Turned out it was a damaged/severed wire going into a junction box and it appeared to have been a fault waiting to happen.. I'd also been stranded by faulty EGR valves a few months prior to this so they weren't the problem in this instance and there wasn't even the option of 'limp' mode! Hope you get it sorted JT |
Sun Jul 15 2012 2:56pm |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
Interesting post! I was travelling on the M4 yesterday towing my twin axle caravan doing about 60+mph, I switched on cruise control and within a few seconds got the "engine system fault" message and the resulting loss of power, I pulled over switched off the engine waited a few seconds and re started, the message had cleared and I drove the 100 miles home with no further issues.
Mon Jul 16 2012 1:45pm |
Just an update on the fault.....Well I have had it plugged in to a diagnostics and guess what...... No Fault!!
Fri Jul 20 2012 8:44pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
The fridge doesn't come on until the engine is running, and then when you turn off the ignition, the fridge will keep running for about 10/15 seconds. |
Fri Jul 20 2012 8:53pm |
Thanks Peanut that has put me at ease on the batt 2009 3.6 TDV8 HST |
Fri Jul 20 2012 8:58pm |
A while back I used to have a Disco 3, which, now and again exiting the Mersey Tunnel, used to lose power and go into limp home mode..I would then stop on the hard shoulder, restart the car and all would be ok. I reckoned it was the auto payment collection beam (which automatically deducts the tunnel fee from a plastic card) upsetting the computer on the D3. Just maybe, your cars electronics threw a wobbler after receiving some odd signal, maybe from an overhead gantry or whatever!! |
Fri Jul 20 2012 9:42pm |
I had only just collected the thing to be honest and I was messing with all the toys like Cruise con....Etc....Etc..... So I just hope I may have scrambled its brain a bit!! 2009 3.6 TDV8 HST |
Fri Jul 20 2012 9:49pm |
