![]() | Home > Maintenance & Modifications > Does suspension knock just disappear? |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Arb bushes |
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 ![]() ![]() ![]() |
Just had same prob on my 2009. Replaced rear sway bar frame bushings and it stopped it. mike murphy |
Thanks for the replies. That's two votes for the arb bushes. I'll probably need to have stealership make an inspection and diagnosis so if anyone can recommend a good one in Hertfordshire....
nobbyk Member Since: 18 May 2012 Location: United Kingdom Posts: 89 ![]() ![]() ![]() |
ARB + 1 |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
the only thing that will disappear is money in your wallet..!! lol i had this problen when i bought mine and had to had some packers fitted at front end somewhere at cost of £130 but did job and still ok 8 months later |
Well the good news is that all is now fixed and car drives beautifully with no knocking noises. Had the diagnosis and work carried out by Chipperfield Land Rover. The workshop had a quick look and recommended fitting new front anti roll bar bushes and clamps; removing the front body dampers and fitting the mass absorber kit (as per LTBs 00241 and 00204).
