Home > For Sale & Wanted > TDV6 of TDV8? |
KnightRRS Member Since: 09 Jul 2012 Location: Carmarthen Posts: 3 |
Fri Jul 13 2012 9:00pm |
That's great, thank you. Is there a 'must have' factory option that I should be looking for?
Sat Jul 14 2012 6:48am |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
All depends on your desires - as an example I really like the fridge and sunroof but never used the TV. For a next car though will defo spec pre-heater. Look for a clean car with clean sound (no whistlling et al) when cold engine turned on - listen from outside. Also adviseable is to look for a car without DPF, which will only cause you troubble if car used on short distances... |
Sat Jul 14 2012 7:22am |
