Home > Maintenance & Modifications > Egr valves, blank or remove??
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
I've just ordered some basic blanking plates after reading on here that the egr valves could be the cause of my cars occasional lazyness, (confirmed by diagnostics). Question is should I blank or get a full removal kit, anyone shed any light on the pro's and con's of each option??
Post #350266 Tue Jul 10 2012 9:15am
Both methods deliver the same results.
If you are fussy, and are either mechanically minded or know of a cheap spanner who'd do it for you then you'd probably opt for the full removal
If you are looking at doing it DIY without much experience in mechanics, then the block off kit suits it's purpose. RRS gone
Post #350272 Tue Jul 10 2012 10:16am
Tony666
Thanks for that, budgets a bit tight after forking out for a new park brake mechanism so I'll fit the blanking plates myself. I've read that I don't need gasket sealer, would you agree??
Post #350291 Tue Jul 10 2012 11:17am
When I was going to do mine (on my old D3) The kit just had 2 oval stainless steel tabs that block the EGR pipes... that was it, no aditional gaskets. Thumbs Up RRS gone
Post #350293 Tue Jul 10 2012 12:20pm
mikey7985
Wales 2009 Range Rover Sport TDV8 HST Stornoway Grey
I thought when you blanked these it meant removing them completely anyway??????? 2009 3.6 TDV8 HST
Post #352142 Sat Jul 28 2012 7:57pm
No Mikey,
Some do, some remove the butterfly valves only, or you can keep the units in place and just blank off the feeds to the intake manifold (pre 2007 cars only) RRS gone
Post #352241 Mon Jul 30 2012 7:53am
mikey7985
Thanks AWD,
So is this the kit for full removal??
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...4605382c40 2009 3.6 TDV8 HST
Post #352245 Mon Jul 30 2012 8:28am
Hmm does not look like it... the instructions show this kit removes the pipework but not the actual EGRs. RRS gone
Post #352247 Mon Jul 30 2012 8:40am
mikey7985
Think I best throw it at the specialist and let them do it!!!! Rolling with laughter 2009 3.6 TDV8 HST
Post #352249 Mon Jul 30 2012 8:55am
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Rather than start a new thread....
Had the car faults read today, and one of the egr valves was on the fault list, so thought it may be best to blank them off (2006 2.7).
With the numerous kits that are out there, whats the difference? Some are a tenner, some are £50?
One more query, this particular seller is stating that the suicide pause on the 2.7 is being caused by the egr valves, I have limited knowledge but didnt think it was down to that?
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...20dddfdc7f
OFTEN WITH THE ENGINE YOU WILL FIND WHEN PULLING OFF FROM A STANDSTILL THERE WILL BE A 2-3 SECODN DELAY BEFORE THE ENGINE PICKS UP. THIS IS DUE TO THE EGR.
Cheers 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #441620 Wed Nov 05 2014 8:24pm
The "suicide pause" is usually caused by the gearbox defaulting to second gear to pull away. Put it in CS 1st as you pull up and you'll find it pulls away much more sharply. 2012 SDV6 - it's missing a couple of cylinders
Post #441631 Wed Nov 05 2014 9:29pm
SRE
Spain
Blank and leave the pipe work in place, then at MOT time everything will look normal.
What delay Question Question BAS remap Bow down Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #441662 Thu Nov 06 2014 7:49am
garrycol
Australia
Remapping does not fix the pause - it is a gearbox programming issue. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #441671 Thu Nov 06 2014 8:55am
darrenmcneill
The remap has helped, and the Pause is a lot less noticeable. My drive to work this morning was quite pleasurable as she skipped through the gears!
Is there anything that can be done with the gears, ive read about re-setting them so they "learn" your driving style.
Back to the egr plates, is there a big difference between the kits out there? I'm presuming stainless steel would be a must, but apart from that all the kits look the same! 2006 HSE for Sale - £7,499 (Manchester)
Post #441720 Thu Nov 06 2014 1:46pm
Tony666
I've used one of the cheap sets, simply two blanking plates, worked a treat. Fitted myself following the instructions with the kit, the only problem I had was the rounding off of two of the bolts, very soft metal, used an irwin socket to remove successfully. No need to remove anything and under the hood looks untouched. I believe the more expensive kits allow you to remove pipework etc, but I didn't feel the need to do that, as I believe it in no way improves performance. Personal choice?
Post #443803 Thu Nov 27 2014 3:21pm
