![]() | Home > Maintenance & Modifications > Body roll 55 plate hse |
Is your vehicle fitted with Dynamic Response? Malaysia Boleh!
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
I dont think so matey, it hasnt got a second resevoir under the bonnet.. |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
how can you see if your sport got the dynamic? |
You must have this yellow...
Mine defo hasn't got response. Any ideas? |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
What are you comparing it with?
Grahamsjz Member Since: 27 Feb 2012 Location: London Posts: 68 ![]() ![]() ![]() |
Sorry to say this but I think there is something wrong with it.
It feels almost like your on a boat? I know the rear bags have recently been done and all four corners are the same height. I just get the feeling the ride should be better for a 40k+ car? How do you go about testing the dampers?
Definately somethibg wrong, my LR3 was a bit floaty but the RR Sport is tight as a drum in corners, no slop at all.
its the same on bumps in roads etc, feels bouncy if you get my drift? kinda roles ab it |
I notice that its a 2005 model and probably needs new shock absorbers with the symptoms that you have described, assuming of course that they have not already been replaced.
I was thinking the same. I don't think they have ever been replaced. Is there a way to test them? Any idea on cost?
Never had one for long enough to have to replace them.
Is there a guide to fitting them at all? Do they just bolt out as there's no springs to compress ? |
