![]() | Home > Maintenance & Modifications > Daylight Running Lights |
Hi Paul, Continuing on..
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 ![]() ![]() ![]() |
I was undecided how I wanted to wire them, I was going to wire them from a switched live under the bonnet but liked the idea of being able to turn them off if needed, In the end I decided to disconnect the front fog lights at the plug and fed DRL's with the fog light feed... So all I do is pull the switch out to put the front fogs on and my DRL's light up instead |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
you need to get a drl switch..i have one and it switchs my drl light on with the ignition and they go out when you put on your headlights..
That's a handy gadget, I might get one |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Probably cheaper to add a relay '08 RRS TDV8
I understand it as if you have got lights fitted no matter what lights they are, then they must work to pass an mot otherwise its a fail. Then maybe not in this case ![]() Ady Last edited by Ady 555 on Fri Mar 04 2011 8:21pm. Edited 1 time in total |
Not true mate, reversing lights are also not part of the MOT test |
Sorry rrs2010, i stand corrected, i will have to check my facts before i post next time |
No problem mate, your not the first to of thought the same |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
nice looking DRL's
nicedayforit Member Since: 12 Mar 2012 Location: Beside the Solway Posts: 25 ![]() ![]() |
You could always do what D3 and FFRR owners do and fit led halos inside the foglights.
Don't like:) think the led strip looks more nice. |
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 ![]() ![]() ![]() |
Very nice indeed, very OEM.. ![]() Where did you get these from rrs2010.? Cheers |
