Home > Technical > 2006 RRS will not Shift Above 3rd Gear
vvrrrmm
United States 2006 Range Rover Sport 4.4 V8 HSE Tonga Green
Help please. Our 2006 Sport will not shift above 3rd gear in automatic mode ( "D"), however I can put it in Sport, then put it back into Drive and it will shift to 4th, but stay now in 4th, and I can do it again and it will shift to 5th, and doing it again will let it go to 6th. I can also put it in Sport Mode then manual and shift up and down manually through all the gears, it just will not do it in D mode. Any thoughts?
Post #349916 Thu Jul 05 2012 6:46pm
Check tyre wear across the axles
Sometimes the different running circumference will stop the autobox shifting above 3rd.
Failing that you need a fluid change....
Failing that the box may be toast.. RRS gone
Post #349960 Fri Jul 06 2012 2:23pm
